One year or so ago i purchased stepper motor package, i have been using the three axis x y z to date with no problems or failures using V carve pro and Mach3.
Several weeks ago i got the bug to set up a 4th axis, made 4 jaw chuck and live center with tailstock, activated the 4th drive with full steps of 200. the jaw chuck is direct drive w/ a flex coupling and several things don't add up!
1. Getting full rotations on diameter with Simple Cylindrical Wrap when drawing on 50% or half of the diameter. as seen on mach toolpath.
2. Setting full step, half,1/4, 1/8 does effect the rotations but still have the rotational thing of multiple rotations.
3. Wrapping around x or y in post processor in V carve.
4. Using radius for feed rate and A rotations enabled in mach and rotation diameter of .0001.
After cycle start x or y z crawl to a stand still when A axis is activated during machining operations.
I have visited both mach and vector forums and at this point i am totally confused.
thanks in advance
tenhrdaz
