Hello fellow DSPMC & Mach3 users,
I recently posted this topic in the general Mach forum and with the help of 'Hood' discovered an issue relating to the saving or altering of mach 3's default softlimits.
I am using mach3 and the dspmc to operate a 3 axis hotwire cutter.
*My problem is, that i can not save softlimits in Mach 3. I have tried saving the profile, starting a new profile and modifying the xml code, all to no avail. When the softlimits are changed and Mach3 is shutdown or the dspmc disconnected the softlimits set in mach3 revert back to there default values of 100 and -100.
*I have installed mach3 on a comp not connected to the dspmc and have no trouble saving the softlimits.
Has anyone experienced this before?
Can anybody help?
Your help in this matter would be greatly appreciated.
Neyland
