Hello Guest it is November 14, 2026, 08:14:29 AM
Author Topic: Please answer the questions correctly.  (Read 10593 times)
« on: December 20, 2011, 07:54:31 PM »
Dear Warp9 Tech Design
I'm going to have questions and input and output numbers assigned as follows: Breakout Board.
"On 12/14/2011 2:33 AM, Kyoji Nonomura wrote:
This is an enquiry e-mail via http://www.warp9td.com from:
Kyoji Nonomura
Dear Warp9
I want to change the functionality of the device.
If you have a comparison table of numbers and pin numbers MACHPIN Breakout Board, I can make a connection.
Motor is connected XYZA
2,3, COM,
4,5, COM
6,7, COM
8,9, COM
But as we understand,
Otherwise I'm not sure about the pin.
Please tell me if you have a terminal connection arrangement table.
Best regards
But you come to the window of the USB driver updates for your reply What is?
"Dear Kyoji Nonomura,
I am forwarding your message to Tech Support (support@warp9td.com) where
Greg will be able to address it.
In the future, please write directly to support@warp9td.com when you
require Technical Support.
Kind Regards,
Stephanie
Stephanie Cary
Customer Sales
Warp9 Tech Design
sales@warp9td.com
www.warp9td.com "
Best regards
