Before we go changing the Wiki, we might want to consider this additional data...
I took my test system, and installed mach 3.32.22 - I did not first uninstall Mach 3.43.37, I just ran the 3.43.22 installer and overwrote the 3.43.37 installation. I then ran drivertest and verified that the PP driver version had changed from 601 to 570.
The I repeated the MSM/1024 lathe tests - all combinations are still good.
I could run mach 1024 lathe and MSM mill in any order and there were no problems.
That tends to say that it is not driver level / mach release dependent as I last suspected.
I heard from Dusty, and he said that after changing from mach 3.43.22 up to 3.32.37 his system now works also (thogh he is experiencing some other issue that show up as a art code).
This makes me wonder is there is some other issue in Dusty's setup - not to pick on Dusty, just noting that the common thing at this point is that system's setup. It's exhibiting unwanted behavior while the same software is running fine on other systems.
I'm not sure what the root issue is/was, but my test show that it is not an MSM issue, and probably not a mach 3.43.22/3.43.37 issue as I've successfully run both of those combinations.... so maybe an wiki update is premature at this time?
