I finally got around to mounting my limit/home switches,here's what I did. I used SPST momentary push button normally on type two conductor switches. I connected them to a cnc4pc breakout board as directed by schematic. Using solid wire to connect them together and shielded wire to connect to breakout terminals via a RCA type plug between board and switch. As for settings I used X++ port 1, pin 10, X-- port 1 pin 11. For X Home port 1, pin 11. For Y++ port 1 pin 12, for Y-- port 1, pin 13, and for Y Home port 1, pin 13. Axis X, Y Homes are shared. I then unchecked the boxes to set them on active high. Now how do I set the soft limits? Is one set to zero and the other set at the length of travel, such as -0 as soft minimum and +12.00 as soft maximum? Can someone with a working machine look over my scenario and recommend the proper changes or tell me what I am doing wrong!. I get the Y axis to work, but the X axis will not, and if I touch the wire that connects the Y switches it triggers the limit on. Also what is a good setting for debounce, whatever that is? Man, I hope someone can help. I'm buggin' on this.
![Huh ???](https://www.machsupport.com/forum/Smileys/default/huh.gif)
