Hello Guest it is December 26, 2024, 03:05:29 PM
Author Topic: Custom Icons, How?  (Read 10881 times)
Offline Scott
  •  140 140
Re: Custom Icons, How?
« Reply #10 on: December 27, 2006, 11:33:29 PM »
You can make a shortcut to your profile with this in the shortcut properties target field "C:\Program Files\Mach3\Mach3.exe" /p YourProfile.  Then give a different name that the installer won't overwrite.
« Last Edit: December 27, 2006, 11:35:56 PM by Scott »
Scott
« Reply #11 on: December 27, 2006, 11:53:20 PM »
Just right click on the icon and name it something like Bretts Mill?
Offline Scott
  •  140 140
« Reply #12 on: December 28, 2006, 12:15:31 AM »
If you have a profile of your own set up, you'll want to be sure that the shortcut target is made to look for that profile by appending the target with  /p "Your Profile Name Here" without the quotes.  Then, yes, right click and rename the shortcut to "Bretts Mill" or "Bretts Mach3.   ;)
Scott
« Reply #13 on: December 28, 2006, 12:28:25 AM »
Thanks Scott,
     Seems I was headed in the right direction and didn't even know it. I think if I update Mach and drag in my various XMLs, they create the profiles automagicly. As long as the xml names stay the same, the icons will work. Mach won't delete my shortcuts or icons because they are not native to Mach. Does that make any sense? Sound about right? Notice the two.
« Last Edit: December 28, 2006, 01:20:15 AM by Chaoticone »
« Reply #14 on: December 28, 2006, 01:06:27 AM »
Yeap,
    That works. I just uninstalled Mach and reinstalled. The first screen shoot is misleading so I'm off to change that.
Thanks everybody.
