Hello
Guest
it is
December 26, 2024, 06:08:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
set up for hot wire foam cutting please
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: set up for hot wire foam cutting please (Read 18718 times)
Carnoustie, Scotland
Re: set up for hot wire foam cutting please
Reply #10 on:
February 05, 2012, 06:11:32 PM »
Machs axis are X Y Z A B C you seem to have U and V in that code. Maybe your CAM has a post processor for Mach or similar?
Logged
lazy mark
24
Reply #11 on:
February 05, 2012, 06:12:46 PM »
hood what does start teach and stop teach do couldn't find it in the mach3 info
mark
Logged
Reply #12 on:
February 05, 2012, 06:17:03 PM »
You can command moves in the MDI line and Teach will record them and make into a gcode file so you can run again without having to enter all the lines manually into MDI again.
Logged
lazy mark
24
Reply #13 on:
February 05, 2012, 06:19:26 PM »
ok just checked foamworks axis designation
x1 =x
y1 =y
x2 =z
y2 =A
that seems ok
Logged
Reply #14 on:
February 05, 2012, 06:20:56 PM »
Yes but code seems to have U and V in it, not sure why.
Logged
lazy mark
24
Reply #15 on:
February 05, 2012, 06:27:21 PM »
hood
import dxf into foamworks4
box says code page is undifined so selected windows baltic does this spread any light
mark
Logged
Reply #16 on:
February 05, 2012, 06:38:06 PM »
Sorry never used foamworks.
Logged
lazy mark
24
Reply #17 on:
February 05, 2012, 06:42:46 PM »
will investigate many thanks for your help hood you give a bit of light at the end of the tunnel and it helps
to push a project on
cheers mark
Logged
lazy mark
24
Reply #18 on:
February 07, 2012, 07:12:53 PM »
hi hood cannot find the fault in mach3 so try ed kcam4 but cannot get the port sorted all settings seem OK i had to put separate parallel port in
mach3 came up that i may have some corrupt memory one of those evenings when ya don't know which way to turn kcam looks good
mark
Logged
Reply #19 on:
February 07, 2012, 07:18:28 PM »
Unless your code is correct for Mach it wont run properly I am afraid, you really need to see if you can get a post processor for your CAM to output in X Y Z etc. Failing that you could likely edit manually by using find and replace in notepad
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
