Hello to all, Hope you can give me a hand.
here is the deal, every time I configure my x++,y++,z++, and apply the settings, hit reset and try to move any axis, mach III informs me a limit switch has been tripped.
Machine is nowhere near any limit switch. I have tested the limit switches and all the wiring, the pins are putting out a constant 4.97 volts. They are wired in serial. I have disconnected wires from the breakout board and measured limit switches resistance while moving the machine, no change in resistance. I switched the pin that was being used for the switches no change.
I have ran out of ideas where the problem could lie.
Also on a less serious note, why does the z axis move up when I am trying to home it? Shouldn't it travel down?
Thank you,
Alonzo
