Hello Guest it is June 23, 2026, 12:06:52 AM
Author Topic: Issue with THC in Mach3  (Read 7235 times)
« on: February 09, 2012, 12:25:14 PM »
The position of my torch proximity switch determines whether the THC-Up or THC-Down signal is high.  In testing my system, I have a switch to signal THC-On and cutting starts after meeting the conditions: a) reach M3 in my code and b) THC-On switch turned on.
I am still unable to to use the the THC-Up and THC-Down signals to control the Z-axis.  What is the protocol for using the THC-Up and THC-Down signals? I initially set the Z-axis value to a number somewhere between THC max and THC min.  After turning on the Torch-On switch and cutting starts, and after I place metal near
the proximity switch, the THC-Up and THC-down signals switch state but there is no output from Mach3 to my z-axis. The THC button is green.
Thanks for any assistance in figuring out what I am missing here.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Issue with THC in Mach3
« Reply #1 on: February 10, 2012, 03:43:17 AM »
Hi griffinf3 - welcome to the forum
post your .xml and we'll take a look.
« Reply #2 on: February 10, 2012, 11:21:44 AM »
Here is the xml and test code.  Thanks for any suggestions you may have.
