I have found through testing that the DRO is more reliable than most indicating devises. The DRO is relative to distance. Actualy if you want to be anal about it one should count the pulses sent by the computer to the drive, from the drive to the motor, and if you have a BOB the in and out of that device should also be counted. In our testing they were all compared via a calibrated multi channel counter accurate to 20 parts per million. So all the measuring done was apples to apples.
A stepper is a eltro-mechanical device and as you know they are all not alike in how they react to a pulse when you get down to the single pulse senerio. So you could for instance find that it it will take more pulses to move it a small distance and it will behave dfferently going the other way. Just test jogging at 0.0001" increments. At 5200 the resolution is
0.00019".
If one adds distance to pulses then the variables associated with the distance must also be callibrated to a known standard. Note that one must be able to decipher what is
contributing to any distance inaccuracy measured and that could be due to a number of things. ie; Backlash can be due to a number of different causes and it can be difficult to narrow it down.
In the end, my point is, one must know exactly what they are measuring and if comparing know exactly what they are comparing and to what degree of accuracy they can compare.
FWIW,
