Hello Guest it is April 26, 2025, 05:12:16 AM
Author Topic: Arduino Modbus, Complete, Documented and free  (Read 275926 times)
Re: Arduino Modbus, Complete, Documented and free
« Reply #50 on: March 22, 2015, 01:59:49 AM »
Hi
Please help fix this error
In file included from ModBusSlave.ino:5:0:
C:\Users\hq01\Desktop\arduino-1.6.0-windows\arduino-1.6.0\libraries\ModBusSlave/Modbus_Slave.h:19:7: error: redefinition of 'class ModBusSlave'
 class ModBusSlave
« Reply #51 on: March 29, 2015, 05:15:24 PM »
great thread.(and thank you shilling)  i made the changes mentioned and got my mega working within an hour or so!
now i just have to do the hard bit- sending/receiving these registers to old i/o cards on my machine via the arduino on  a seperate com port.
stupid things have 192600 baud rate and an xor checksum ..... wish me luck!
if its not broken yet, fit more gadgets!
Offline nso
  •  36 36
« Reply #52 on: October 05, 2015, 12:22:48 AM »
hi everyone
i have a problem,  i have tried to upload arduino uno i got an error message. so what shall i do to handle it?
Offline dude1
  •  1,253 1,253
« Reply #53 on: October 05, 2015, 01:25:36 AM »
update the usb driver`s also the modbus was written for a earlier version of arduino
have a look here it may help https://learn.adafruit.com/lesson-0-getting-started/installing-arduino-windows
Offline nso
  •  36 36
« Reply #54 on: October 05, 2015, 02:00:40 PM »
thanks for your quick replay ,after that i am sure about usb port and arduino  version because i have done it  whit zafar s sketch  (analog input) and that is worked great ....then when i tried whit shilling sketch that error happened.
sorry ,i know my English is awful
Offline dude1
  •  1,253 1,253
« Reply #55 on: October 05, 2015, 03:38:19 PM »
there will be a need to change some bit`s of the code I cant rember what to long ago and ask on the arduino form
Offline nso
  •  36 36
« Reply #56 on: October 05, 2015, 11:18:11 PM »
no problem,anyway thank you.
« Reply #57 on: October 16, 2015, 06:34:15 PM »
Hi there...
I tried to compile the modbus code but I'm getting an error... missing the WProgram.h
Any suggestions about this?
Kind regards
Offline dude1
  •  1,253 1,253
« Reply #58 on: October 16, 2015, 08:06:18 PM »
look here http://forum.arduino.cc/index.php?topic=147680.0
the WProgram.h is from v1 of arduino it got changed to Arduino.h
« Reply #59 on: October 17, 2015, 05:44:32 AM »
Thank you for your help...
Now I have some inputs working with leds, some blinking, some fixed but I noticed that just some arduino mega ports from the main row (2 to 12) are working as outputs and none of the extra ports are working (22 to 53).
Can some one explain to me which ports are usable as output / inputs and how to enable the extra ports of the arduino mega?
Is it possible to connect more than one arduino mega to the system? Is there a limit of arduino or ports on the system?
Just one more question, how can I setup a rotary encoder on the mega and mach3 to work as a MPG?
I would like to build a console to my milling machine with as many functions as possible (buttons, leds, switches, etc...)
Thank you in advance
Regards
