Hello
Guest
it is
September 01, 2024, 01:28:47 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Control spindle speed with potentiometer and pokeys board
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Control spindle speed with potentiometer and pokeys board (Read 5344 times)
remartinez
29
on:
April 05, 2012, 01:07:47 PM »
Hi all
I need some help!
I have a pokeys 56U board and I have a potentiometer connected to it. I want to able to control my spindle speed with it. How would I go about doing this. Would I need to use brains? If so what formula would I need?
I also want to be able to change the feed rate with a different potentiometer.
Raul
Logged
Carnoustie, Scotland
Re: Control spindle speed with potentiometer and pokeys board
Reply #1 on:
April 05, 2012, 01:45:25 PM »
You can use a Brain or the macropump. I have posted Brans before in the pokeys section that I used for FRO and SRO.
Logged
remartinez
29
Reply #2 on:
April 05, 2012, 01:59:06 PM »
Hood,
Thank you for your response. I am trying to find your post. Any chance you can give me the link to your post on the FRO and SRO.
Thanks again,
Raul
Logged
Reply #3 on:
April 05, 2012, 02:05:15 PM »
http://www.machsupport.com/forum/index.php/topic,11817.0.html
Logged
remartinez
29
Reply #4 on:
April 05, 2012, 02:13:57 PM »
Thank you once again.
Raul
Logged
Reply #5 on:
April 05, 2012, 02:22:50 PM »
No problem. I have not looked at the Brains I linked to since I posted but I am almost certain they are the same as I use now with the exception of the formula will be slightly different as I now use a PLC for the pots rather than the PoKeys.
Logged
Print
Pages:
1
Go Up
« previous
next »
