Hello Guest it is September 30, 2026, 12:18:08 AM
Author Topic: PS3 controller help  (Read 14449 times)
PS3 controller help
« on: April 11, 2012, 10:12:55 AM »
I set up a PS3 controller and it works great, but it will only work if I open up keygrabber first and then load mach 3. Is there something in mach 3 I need to configure so I don't have to open keygrabber every time?
Re: PS3 controller help
« Reply #1 on: April 12, 2012, 05:19:42 PM »
You can change the target of your shortcut to open keygrabber and then have keygrabber  open your Mach profile.
Its been a long time since I did that and cant remember but will look to see if I can find the info.
« Reply #2 on: April 12, 2012, 05:27:46 PM »
Ok try this, seems to work here anyway.
Right click on your Mach shortcut and choose properties. In the target field enter this
C:\Mach3\KeyGrabber.exe /p MyProfile
The "MyProfile" will be the name of the profile you are using, for example if its the standard Mach3Mill profile the target would be
C:\Mach3\KeyGrabber.exe /p Mach3Mill
Also note that there is a space before and after the /p
« Reply #3 on: April 14, 2012, 09:00:29 AM »
Hey that works!  ;)
Thanks!
« Reply #4 on: April 14, 2012, 09:04:28 AM »
Here's a video I made if anyone else is trying to do it.
http://www.youtube.com/watch?v=ChyLKj0ne1g
