Hi Dwayne,
Yes, hook it up to use the "Probe" input and in "Ports and Pins", set the proper port and pin number with active low. Then just set up a button with the needed script. I have found that I still need to fudge the plate thickness just a little (by way of a user DRO on the settings page), so you may need to experiment a little to find that sweet spot. Other than that, I have had no problems with noise.
