Hello
Guest
it is
September 01, 2024, 02:30:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Moving 'Z' .001 at a time
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Moving 'Z' .001 at a time (Read 4195 times)
gene8522
117
on:
April 25, 2012, 10:46:16 AM »
I saw in a YouTube that if you press "Ctrl" and move X Y or Z. It will move .001 at a time. I have tried this and it works on this PC. But the PC that my CNC is hooked to will not do the .001 move. If I press "Ctrl" on the CNC-PC the DRO starts moving an will not stop until I press reset. I tried to reinstall Mach3 with no change. Both PCs are running Mach3 version R3.043.056 W/ Mach2010 screenset. It's not mandatory that I be able to use the .001 move, but I can see where it would come in handy at times. Am I missing a setting somewhere on the CNC-PC?
Logged
Carnoustie, Scotland
Re: Moving 'Z' .001 at a time
Reply #1 on:
April 25, 2012, 10:53:48 AM »
Check the size of the step you have, it could be you have a large step distance. On the standard screen you can get that by pressing the Tab on your keyboard, no idea if its the same on Gerrys screenset.
Logged
gene8522
117
Reply #2 on:
April 25, 2012, 02:07:59 PM »
If I press 'Tab' it brings up the MPC Mode.
Logged
Reply #3 on:
April 25, 2012, 02:10:56 PM »
As said I do not know anything about that screenset but if there is a DRO with step size or something similar then make sure it is set to 0.001 if that is what you want.
Logged
gene8522
117
Reply #4 on:
April 25, 2012, 02:34:55 PM »
You right AGAIN
My step increments was set at 6.0000. Changed to .001 But ................... the .0001 changes. But now I know where I need to look. The problem now is it will not change a whole number like .001 but .0009 or
Logged
Reply #5 on:
April 25, 2012, 02:37:54 PM »
What are your steps per unit, it could be Mach can not physically move 0.001.
Logged
gene8522
117
Reply #6 on:
April 25, 2012, 03:19:10 PM »
Under Motor Turning
Steps per
X = 1420.682611
Y = 1422.456593
Z = 1602.187457
Logged
Reply #7 on:
April 25, 2012, 03:48:06 PM »
The X is 0.000704 approx per step so Mach could not move 0.001 exactly as it can only step in increments of 0.000704
Your other axes would be similar.
Logged
ger21
6,295
Reply #8 on:
April 25, 2012, 06:57:35 PM »
With the 2010 Screenset, if you set up your jog increments on the Settings tab, you can cycle through them with the + and - keys while on the Jog Tab. You can use the "End" key to toggle between continuous ans step jog modes.
Logged
Print
Pages:
1
Go Up
« previous
next »
