Hello Guest it is April 04, 2025, 08:08:32 PM
Author Topic: multiple tools offset question  (Read 4571 times)
« on: April 25, 2012, 11:23:40 AM »
Despite setting and saving a tool off set( it's a shorter tool than tool zero), when Mach 3 goes from a drilling operation to a contouring, with a different tool,
the offset does not take. Essentially, the new tool falls short of its zero point on the workpiece.  I don't get it.
For perspective sake, tool 0 is set at 0 in the offset table, and the tools preceding the countouring operation appear to work fine, since they all have the same length.  When I change the tool to do the contouring, with an offset of -.500( half inch shorter than tool 0) in the tool table, the program does not recognize it.
Mach 3 does know when it's a tool change.
Any help is greatly appreciated.
tc
Re: multiple tools offset question
« Reply #1 on: April 25, 2012, 11:27:19 AM »
G43H* needs to be called where the * is the offset number in the tooltable you wish to call.
« Reply #2 on: April 25, 2012, 11:29:37 AM »
It really is NOT a good idea to use TOOL 0 in Mach3 as you may have found. It is a reference point for Mach3.
Just a thought,
« Reply #3 on: April 25, 2012, 12:10:39 PM »
Thanks a lot. It was the infamous G43 that was missing from my code. The post processor Mach3B, for some reason, leaves it out. I had used this on an old program.
tc
