Hello Guest it is September 01, 2024, 01:41:57 AM
Author Topic: Probe not responding  (Read 3245 times)
Offline Ben
  •  79 79
« on: April 27, 2012, 05:51:38 PM »
I'm trying to get my probe to work again. In port and pins I have Index disabled and Probe enabled, assigned to port 1 pin 15 and active low.
When I touch it to the touch plate the led on the BOB flashes each time and on the settings page the "Port 1 Pins current
State" changes also, but the program won't respond.  At one time this all worked (last year) so I'm checking the Gcode last.
Have I missed a setting somewhere?  Should the Index or Digitize LED on the settings page light up? What's your thoughts?
Thanks, Ben
Re: Probe not responding
« Reply #1 on: April 27, 2012, 07:19:33 PM »
The digitize LED on the settings page should light up.
Offline Ben
  •  79 79
« Reply #2 on: April 28, 2012, 09:33:42 AM »
The pin LED says that Mach knows that pin 15 has a signal but doesn't realize that it's a probe, so it's not lighting the digitizing LED.  So I think there is something
I've missed in the setup.
Ben
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #3 on: April 28, 2012, 11:16:20 AM »
check you don't have emulated ticked.
Offline Ben
  •  79 79
« Reply #4 on: April 28, 2012, 01:55:06 PM »
WOW!  Nice catch, that fixed it. Good job and thanks for the help.
Ben
