Hello
Guest
it is
October 06, 2024, 08:34:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Changing the XML file that a Screenset uses.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Changing the XML file that a Screenset uses. (Read 2774 times)
btu44
28
on:
May 16, 2012, 03:44:50 PM »
Hello,
I have made a copy of my current Screenset and its associated XML that I will use for mod testing.
How can I get the 'copied Screenset' to use the 'copied XML' and not the original XML file?
(Yes, they have been renamed)
Barry
Logged
Carnoustie, Scotland
Re: Changing the XML file that a Screenset uses.
Reply #1 on:
May 16, 2012, 04:29:06 PM »
By xml are you meaning the Mach profile?
Not really sure what your question is as opening a profile then loading a screenset will associate that screenset with the profile. The change will only be saved when you shut Mach down though.
Logged
btu44
28
Reply #2 on:
May 16, 2012, 05:03:03 PM »
Thanks for replying.
What I did was copy and rename the .set & .xml files. Then I changed the shortcut to use these files.
After posting, I realized I should Create & Clone the in Mach3 Loader...much better.
Thanks again.
Barry
Logged
Print
Pages:
1
Go Up
« previous
next »
