Hello Guest it is December 26, 2024, 06:00:09 AM
Author Topic: Moving to another PC  (Read 5721 times)
« on: May 25, 2012, 11:01:07 AM »
I know it can be done, I think I was told to save an transfer an XML? Is this correct? When I look at the folder called XML, there are a bunch of XML's in there. Do I copy the entire folder? Or better yet, can someone give me or point me toward a play by play of transferring to another computer? Thanks, Mike
Re: Moving to another PC
« Reply #1 on: May 25, 2012, 01:09:12 PM »
Open Mach and lower right of the main page you wll see the name of the profile you are using. Look in the main Mach3 folder for a file of that name with a xml file extension. The XML folder is a backup folder and contains automatically saved backups but its not really what you are wanting.
Other things you want to copy are the licence (assuming you are not using Mach in Demo) Any custom macros you may have, any brains you may have and if using a non standard screen then save it and any associated bitmaps for it.
« Reply #2 on: May 25, 2012, 03:45:19 PM »
OK so I need the xml or I don't need the xml?
« Reply #3 on: May 25, 2012, 03:50:12 PM »
You need the xml but not the backup xml .
 The xml is in the Mach3 folder, the backups are in the  xml folder.
« Reply #4 on: May 25, 2012, 06:22:08 PM »
they're easy to find if you view the list by type, then the xml files are at the end of the list together.
« Reply #5 on: May 25, 2012, 07:22:16 PM »
I see one called MachXML, liiks like a zip (pile of books) Is that the one?
« Reply #6 on: May 26, 2012, 02:21:22 AM »
No it is a single file you are looking for.
As said earlier open Mach and look at lower right of your main screen and you will see the name of the profile you are using.
If for example it was the standard Mill profile it would say Mach3Mill.
Next close Mach then browse to the Mach3 folder and look for a file called Mach3Mill.xml, see screenshot.
« Reply #7 on: May 26, 2012, 10:45:40 AM »
Heres a screen shot of my Mach3 folder, maybe I'm blind but I don't see it!
« Reply #8 on: May 26, 2012, 10:49:24 AM »
9th column 6th row
Offline Bloy
  •  158 158
« Reply #9 on: May 26, 2012, 10:59:44 AM »
This is the file.  The .XML is not showing as per windows settings.
