Hello Guest it is December 21, 2024, 11:57:03 AM
Author Topic: #variable use in Mach3  (Read 27062 times)
« on: June 02, 2012, 08:26:53 PM »
Does Mach 3 support #variable use in programming. The simulation toolpath in Mach doesn't seem to like it.
Here is an example below.
O0001(MACRO PROGRAM TEST)
G20
G00 G17 G40 G49 G80 G90
M998
(1/4 4fl. endmill)
T2 M06 G43 H2
S1000 M03
G54 X2.0Y2.0
Z.1
(INTERPOLATE 2.0 DIA. HOLES)
#100 = 2.0(CIRCLE DIA.)
#101 = 10.0(LEADIN FEED)
#102 = 20.0(FULL CIRCLE FEED)
#103 = 40.0(LEADOUT FEED)
#104 = -.25(ABSOLUTE Z DEPTH)
#105 = 10.0(Z PLUNGE FEED)
M98 P0002
X-2.0Y-2.0
M98 P0002
M5
M998
M30
O0002(SUB INTERPOLATE CIRCLE)
(STARTS AT CENTER)
G1Z-[#104]F[#105]
G91
G3X0Y[#100/2]R[#100/4]F[#101]
X0Y-[#100]R[#100/2]F[#102]
X0Y[#100]R[#100/2]
X0Y-[#100/2][#100/4]F[#103]
G90
G0Z.1
M99
Re: #variable use in Mach3
« Reply #1 on: June 02, 2012, 09:25:45 PM »
G20
M998
(1/4 4fl. endmill)
T2 M06 G43 H2
S1000 M03
G54 X2.0Y2.0
Z.1
M98 P0002
X-2.0Y-2.0
M98 P0002
M5
M998
M30
(STARTS AT CENTER)
G1 Z[#104*-1] F[#105]
G91
G3 X0 Y[#100/2] R[#100/4] F[#101]
X0 Y[#100*-1] R[#100/2] F[#102]
X0 Y[#100] R[#100/2]
X0 Y[#100*-1/2] R[#100/4] F[#103]
G90
G0Z.1
M99
« Reply #2 on: June 02, 2012, 09:44:34 PM »
YaNVR got you set up(;-)
With Mach3 you cannot use the - directional sign with a #var. You have to solve inside the brackets to make the #var negative.
AND Yes I know that ain't right BUT that is just the way it works in MAch3 .
« Reply #3 on: June 03, 2012, 09:05:10 AM »
Thanks guys I'll give it a try. I was used to fanuc style programming. But that tip shed some light on the subject.
« Reply #4 on: March 29, 2013, 01:16:05 PM »
what about if statement in mach3, is it possible to use it? what will be the format of it?
sting
« Reply #5 on: March 29, 2013, 01:20:00 PM »
There is NO conditional in Mach3 gcode.
« Reply #6 on: March 30, 2013, 08:34:54 PM »
A few tips-
Regarding assigning parameters to negated values-
#1 = -#2 (Doesn't work)
#1 = [-#2] (Doesn't work)
#1 = [#2/-1] (Works)
Although there are no conditionals, to get conditional processing I often use L param in subroutine calls to conditionally execute code based on a variable being zero or non-zero. Its a hack but it works, see below.
This runs the subroutine one time if #106 is non-zero, doesn't run if #106 is zero.
M98 P1351 L[ROUND[[#106 + 0.00001]/[#106 + 0.00003]]]
« Reply #7 on: March 30, 2013, 08:59:07 PM »
Also:
#1 = [0 - #2]
#1 = [#2 * -1]
« Reply #8 on: March 30, 2013, 09:06:29 PM »
Redirection from Gcode
M1000 R29    (R sets the Goto #)
o29 (o word somewhere in your code you need to GOTO)
M1000 Code
Code"M98 P" & Param1()
A little strange but it does work
Just a thought, (;-)TP
« Last Edit: March 30, 2013, 09:22:20 PM by BR549 »
« Reply #9 on: March 30, 2013, 09:24:21 PM »
The M1000 code should read
Code"M98 P" & Param3()       'to use the R param
