Hello Guest it is September 13, 2026, 04:55:56 PM
Author Topic: EX_COMMAND Plugin  (Read 6085 times)
EX_COMMAND Plugin
« on: June 12, 2012, 03:46:36 PM »
I managed to get a command mode plugin working, but I am now having problems with a client that is specifying a feed on each g-code line. What happens is that in this case Mach3 seems reluctant to keep sending external movements and with an end result that I get a command then about 20 empty update command and then a new command. This does not allow the machine continues movements. IF I remove the F words from the G-Code lines everything behaves as it should. Can you shed some light on this logic (I can send logs to clarify the situation) ?
Alfredo
