Hello Guest it is March 13, 2025, 07:47:50 PM
Author Topic: Script Editor Font Too Small  (Read 14514 times)
Re: Script Editor Font Too Small
« Reply #20 on: June 18, 2012, 02:26:48 PM »
Not sure what fixed it, but it is back to normal !
While the DPI was at 120, I rolled the mouse wheel with Ctrl and the font shifted to the right a few clicks then enlarged.
Set the DPI back to 97, rebooted and all is well now.
Don't know if it was the toggled DPI setting that straightened it out or if the Ctrl/wheel would have straightened it out by itself. ? ? ?
Either way, it is OK now.
Thank you all very much,
Russ
« Reply #21 on: June 18, 2012, 02:44:59 PM »
I'm telling ya Ya-Nvr-No
#@% Computers
Glad to see it is fixed  ;D
« Reply #22 on: June 18, 2012, 02:50:21 PM »
Russ, dont fook it up again I dont have much hair to pull out ;D
« Reply #23 on: June 18, 2012, 02:55:43 PM »
 :D
I'll try not to.
Dont know how I fooked it, but at least I know how to un-fook it if it ever happens again. ;D
Thanks Hood,
Russ
« Reply #24 on: June 19, 2012, 11:42:50 AM »
Now how did that fix go , Stand on your left leg while sticking out your tongue then press the button and drink a beer at the same time. Spin 3 circles and FIXED??
Yea buddy, You did good.  (;-) TP
« Reply #25 on: June 19, 2012, 12:01:55 PM »
THis is kinda like the problem With designing Wizards. You can place the jog control ON the screen correctly. BUT the Keyboard Jog Hotkeys will NOT work when you first load the wizard to use. You must then OPEN the hotkeys config page, Do nothing as the info is still there, then close it down and save the screenset. THEN the jog control hotkeys will work from then on.
« Reply #26 on: June 19, 2012, 12:53:27 PM »
:D
It actually took SEVERAL beers, and I think it also required a second mouse.
Now that I can read the code, I'll probably be hitting you up for some macro help soon Terry.
Thanks a bunch,
Russ
