Hello Guest it is September 27, 2026, 01:27:45 AM
Author Topic: RunScript() ??  (Read 8345 times)
RunScript() ??
« on: June 13, 2012, 05:52:39 PM »
Anyone out there able to make RunScript()  work?
Re: RunScript() ??
« Reply #1 on: June 13, 2012, 07:52:34 PM »
OK FINALLY figured it out.
RunScript(" macros\mach3mill\MsgBoxScript")
YOU have to give it a "partial path"  so it can find the file ????.  THAT is not mention in any example explanation. It shows JUST using the filename .
Normally you would use the ENTIRE PATH or just the file name assuming MACH3 KNOWS where you are suppose to put the file.(;-)
Never saw it done this way.
VERY confusing so say the least, (;-) TP
