Hello Guest it is December 27, 2024, 01:57:47 PM
Author Topic: MACH 3 NOT RESPONSIVE!!! HELP  (Read 3480 times)
« on: June 21, 2012, 10:50:08 AM »
I'm having trouble with my Mach 3 machine.
I checked that it was in the right printer port from the mach support videos and made sure the circuits and and everything is in tact. Everything seems to be correct but my computer controls for the mach 3 program is still not controlling the actual machine. Do I have to uninstall it and reinstall it again maybe? For some reason when I programed the mach 3 on my computer I did not have to do any further installing, instead I only opened through it from my USB drive. The controls on my jog seem to work but nothing on the machine is responsive!
Also, my computer is running on Windows XP 2002 on a 32-bit.
PLEASE HELP!!!!!
Re: MACH 3 NOT RESPONSIVE!!! HELP
« Reply #1 on: June 21, 2012, 04:56:24 PM »
Try running the driver test as that will install the driver. Make sure the PP is defined  with correct address in your config.
