Hello Guest it is June 30, 2026, 06:45:59 AM
Author Topic: Galil Connector  (Read 63855 times)
Re: Galil Connector
« Reply #10 on: December 12, 2013, 04:05:45 PM »
Drive enable is a function of the Mach enables.  I believe you can stagger the enable delay in Mach 3, but I do not know how.  You may want to pose that question in the General section.
Steve
I think it is pre-set in Mach and you can not change. I cant recall the time differences but Enable 1 is first then a short time later Enable 2 etc.
Re: Galil Connector
« Reply #11 on: December 13, 2013, 03:22:28 PM »
Thanks Hood
I understand the great idea to lower the shoke load on mains get distributed over switching the drives 1 at the time, slight picle with Mtsu there not enoth delay as I us diffeent power drives and they have diferent tme delays on they own and some time two 400W ones click together they trigger RCD right away  >:D.  Should I use just ordinary fuse?
Re: Galil Connector
« Reply #12 on: December 13, 2013, 04:36:18 PM »
Probably a D Rated breaker would be fine.
Re: Galil Connector
« Reply #13 on: November 18, 2014, 07:20:08 AM »
A similar connector is available in the US from Digikey, P/N 5175677-9-ND with ribbon cable P/N MB100G-5-ND for 5 foot cable. From what I can tell it should work, but have not tried it.
