Hello Guest it is March 13, 2025, 03:29:42 PM
Author Topic: Joypad Plugin  (Read 6798 times)
Joypad Plugin
« on: June 28, 2012, 01:56:07 PM »
I have installed the joy pad plug-in, with the Logitech attack three joystick. I can get incremental movement on the joysticks but not continuous. The manual says: "To switch to continuous jogging just release the Alt button and use Safety button
instead." This doesn't work for me. I need some help to activate continuous jogging with the joystick.
Re: Joypad Plugin
« Reply #1 on: July 03, 2012, 12:01:29 AM »
Help?
Re: Joypad Plugin
« Reply #2 on: July 21, 2012, 02:16:10 AM »
I purchased a Joypad and set it up. It does'nt work either. Please help me. I really want this to work.
Re: Joypad Plugin
« Reply #3 on: July 21, 2012, 08:51:26 AM »
I would ask this question in the appropriate plug-ins forum as you'll get a better response from the builders over there.  ;)
Re: Joypad Plugin
« Reply #4 on: July 21, 2012, 04:21:56 PM »
Thank you, I will do that. How do I find the "plug-ins forum"?
Re: Joypad Plugin
« Reply #5 on: July 21, 2012, 04:26:00 PM »
Oh, I think I found it. I posted over there first, but nobody's talking.
Re: Joypad Plugin
« Reply #6 on: July 21, 2012, 05:20:42 PM »
That is because VERY few people work on plugins. So you have to be patient and wait on someone to respond.
Just a thought, (;-) TP
new person
« Reply #7 on: July 21, 2012, 07:33:30 PM »
Hello
I am very new to the Mach3 world and I am trying to get my CNC plasma table working on my desktop I have a few Mach short cuts when I click on plasma the next page is not always the same the machine always says out of machine soft limits when I make a program in Bob cad and load it say two rows of circles it only cuts the first circle could someone help me answer some of my questions? thanks George
Re: Joypad Plugin
« Reply #8 on: February 10, 2015, 10:39:04 AM »
Problem opening joypad setup
I have downloaded the joypad setup from this site but when i push joypad setup it says:"JoyPadSetup.exe-.NET Framework Initialization Error, Unable to find a version of the runtime to run this application". What can i do to fix this problem?
I use XP and have .NET Framework C++ 4.0 installed.
Best regards Tom
