Hi!
I have installed my C3 and it works well. I get good RPM readings from the spindle into Mach3.
But when I try to cut threads it will not move at all when I get to the G76 line. I have tried alot of different settings; differnet values on Index Debounce, different setting on the Spindle setup under Ports and Pins etc...
When I am at the diagnosticspage the Index is working but the Wait for trigger and Threading is not marked.
I have read the settingssection in the Mach3_Threading manual.
There are two jumpers on the C3 board; Active low or Active high output signal and TTL or Open collector output signal. What is this? Is there any settings there that might chance my results.
Any other suggestions?? This is really freaking my out
![Sad :(](https://www.machsupport.com/forum/Smileys/default/sad.gif)
Regards
Per
