Hello Ruffi,
Thanks for the reply. Yes, I've already made. Buffer = 5%-10%
But when I processed 3 million lines with 3000mm/min I need the buffer.
Otherwise, the machine sputters.
If I have a new part on the machine, it is very dangerous if the feed is 10-100 lines are coming to stop.Has there been a few times a loss!
How do you solve this problem?
I hope that when I bring the analog values directly from DSPMC-7762M in the controller. I have not the Responsetime from the Pokey by the USB
The feed should not be dependent on the buffer!
For all machine tool manufacturers such feed G01 and GO pot responds instantly.
Have you an example, how do I get an analogue value in Mach3 to Brain
Thank you for your help and possible for an example
Guido
