Hello Guest it is December 26, 2024, 08:14:43 PM
Author Topic: re:CNC Lathe program  (Read 49459 times)
Re: re:CNC Lathe program
« Reply #80 on: August 08, 2012, 03:53:38 PM »
Thanks to many buttons
« Reply #81 on: August 08, 2012, 03:59:49 PM »
 OK, went to config ports and pins found that reverse arcs was already checked but it was in radius so i checked the dia and loaded the balls same thing crop circles.
Dennis
« Reply #82 on: August 08, 2012, 04:09:13 PM »
Attach your xml and I will have a look.
« Reply #83 on: August 08, 2012, 04:32:25 PM »
Thanks here it is.
Dennis
« Reply #84 on: August 08, 2012, 05:04:03 PM »
Dennis, that has a Mill screen loaded so I think it must be the wrong xml.
« Reply #85 on: August 08, 2012, 05:12:36 PM »
After changing the IK mode, are you Regenerating the toolpath/file ?
It won't show correctly until you do.
Maybe ?
Russ
« Reply #86 on: August 08, 2012, 05:25:58 PM »
See attached.....
« Reply #87 on: August 08, 2012, 08:49:36 PM »
Rich
 Yes it is the same screen as is used in the mill application but i modified it to use in the lathe as i did not like the lathe screen you may be right so i will change the screen to the lathe screen set up and see what happens.
Dennis
« Reply #88 on: August 09, 2012, 02:46:56 AM »
You can use the Mill screen but you MUST change the file extension to .lset. If  you dont then Mach will treat it as a mill.
« Reply #89 on: August 09, 2012, 01:13:04 PM »
That's exactly what i did changed it to Lset unless when i did an update the update changed it back to Mill set. Just took a look at Mach and see there are more then one XML also i looked and the screen set is named 1024 Lset so don't know whats up?
Dennis
« Last Edit: August 09, 2012, 01:21:45 PM by DennisF »
