Hello
Guest
it is
December 26, 2024, 01:43:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Index problems
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Index problems (Read 7727 times)
jab_814
42
Re: Index problems
Reply #10 on:
August 07, 2012, 02:29:53 PM »
As of now no all inputs are used , I currently have the A and B for mpg , one for limits , and one for an optical sensor for a home/ limit for the z . Do you think I could slide the a and b over to the pokeys or even the home and limit switch .
Logged
Carnoustie, Scotland
Re: Index problems
Reply #11 on:
August 07, 2012, 02:32:57 PM »
I would definitelky leave the Home/limits on the parallel port so possibly the MPG would be the one to change over. I have not tested the MPG on the latest PoKeys plugin but I think it works reasonably well.
Logged
jab_814
42
Re: Index problems
Reply #12 on:
August 10, 2012, 03:23:04 PM »
It works now, I did what hood mentioned and that corrected the problem. Thanks hood I appreciate your response .
Logged
Re: Index problems
Reply #13 on:
August 10, 2012, 03:38:16 PM »
Glad you got it
Did you hook the MPG via the PoKeys? If yes does it work well
Logged
jab_814
42
Re: Index problems
Reply #14 on:
August 10, 2012, 06:45:11 PM »
Um I haven't got it to work yet . Didn't spend much time . But what I did was enable fast encoders , pins 1 A , 2 B. but I didn't get it too work . Don't know how to tell Mach 3
Logged
Re: Index problems
Reply #15 on:
August 10, 2012, 07:10:49 PM »
I did try it out with the Alpha plugin a while back but its totally different now, will have a look and see what you have to do but think its all plugin and you dont have to do anything in Mach.
Logged
Re: Index problems
Reply #16 on:
August 10, 2012, 07:24:26 PM »
Kind of looks like you would just select the MPG DRO in the drop down list on the plugin page.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
