Hello Guest it is September 25, 2026, 10:22:38 AM
Author Topic: Mach3 turn atc  (Read 72213 times)
Re: Mach3 turn atc
« Reply #20 on: September 10, 2012, 12:21:10 PM »
jasminder, its a worm drive.
do i need to keep vb script running in the back ground or just close it.
when i push the play button on the vb script it asks me for current tool and the turret will move a bit.
but when i type t0202 into the mdi bar nothing happens
Re: Mach3 turn atc
« Reply #21 on: September 10, 2012, 12:27:52 PM »
you gotta type t0202 M6
jasminder
Re: Mach3 turn atc
« Reply #22 on: September 10, 2012, 12:28:34 PM »
remember that the m6 calls for the start and stop macros for the tool change
regards,
Jasminder
Re: Mach3 turn atc
« Reply #23 on: September 10, 2012, 12:29:35 PM »
I need some drawings/design idea of your turret .
Do you have any links or PDF of the machine or turret?
regards,
Jasminder singh
Re: Mach3 turn atc
« Reply #24 on: September 10, 2012, 12:37:16 PM »
i will see what i can find.
still not working sorry
Re: Mach3 turn atc
« Reply #25 on: September 10, 2012, 12:38:58 PM »
M6 is not required in Mach Turn. The correct way to call a tool change in Mach Turn is T0202. This will automatically call the M6Start macro.
You do not need the VB script editor be open in the background. Save it and close the window. Make sure you are saving the M6Start for the correct profile as I mentioned earlier. Also could be Mach is already at tool #2 when you issue T0202 so nothing happens. Check the Tool DRO in Mach.
Re: Mach3 turn atc
« Reply #26 on: September 10, 2012, 12:42:27 PM »
dont have a dro for the a axis, but i am alternating between tools. according to the tool no on mach
Re: Mach3 turn atc
« Reply #27 on: September 10, 2012, 12:44:00 PM »
Please attach you XML file.
Re: Mach3 turn atc
« Reply #28 on: September 10, 2012, 12:48:59 PM »
thanks
Re: Mach3 turn atc
« Reply #29 on: September 10, 2012, 12:56:32 PM »
Looks good here. Is you profile name "cnclathe"? If so, do you have the M6Start macro under C:\Mach3\macros\cnclathe ?
