Hello
Guest
it is
October 06, 2024, 09:10:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
siemens turning software
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: siemens turning software (Read 2376 times)
Fred_evans
396
on:
September 10, 2012, 02:44:01 PM »
Hi guys-- can someone please help me??
If I use siemens turning cam software will the resulting gcode be able to run
on a lathe application on mach3??
regards fred
Logged
Dan13
1,208
Re: siemens turning software
Reply #1 on:
September 11, 2012, 02:35:21 AM »
As long as you have the right postprocessor that will output Gcode compatible with Mach3 you're fine.
Logged
Print
Pages:
1
Go Up
« previous
next »
