Hello Guest it is May 23, 2025, 01:52:00 AM
Author Topic: 4 axis problems  (Read 4579 times)
Offline swets
  •  52 52
  • www.arjan-swets.com
4 axis problems
« on: September 12, 2012, 04:48:11 PM »
I've recently a 4th axis on my machine... but It don't works alright .....
I make toolpad with visualmill 6.0...
first a mill then top, then rotate 90 degrees, mill the left side, rotate 90 degrees again ....etc... etc..... so i mill the 4 sides.... and this works alright....
but then I want to finish, to let the A axis to rotate, and mill the outside...   but that did not go oke...  the A axis keep turning, and the Z-axis don't move alright....
it seemed like the A-axis goes  via wrong side to the next point .....?
somebody tell me , to turn on the "Shortest Rot"
but I can't found that?
It must be in the menu : "Config>State"
but I don;t have State by Config ???
so , is there somebody that Knows what can be the problem? and where i can found "Shortest Rot."?
sorry for the bad english!
Re: 4 axis problems
« Reply #1 on: September 12, 2012, 04:58:36 PM »
Y0u will find it under General Config, lower center of the screen "Rotational". There are three settings and what each does is in the Mach Manual.
Offline swets
  •  52 52
Re: 4 axis problems
« Reply #2 on: September 12, 2012, 05:24:05 PM »
"Ang Short Rot on G0" is the same?
and is that my problem?
Re: 4 axis problems
« Reply #3 on: September 12, 2012, 08:25:02 PM »
Don't know ....Mach implements the code given to it and the code needs to be correct for how Mach is configured.
