Hello TP,
I am using mach3 for turning
I have home switches and do "set home X"" set home z" aty startup
I am reading a post that you made on the 12th march regarding the use of g28 or g30
to return to the home position
Your suggestion was that g30 x0 "would will home X first then z"
I put the block in and it moved the tool to z0 ( centreline of chuck) before going to Z0
Have i done something wrong?
I want to put a block in that causes the tool to move away from the job on the x axis and then move to the
z axis home position??
Best regards
fred
