Hello Guest it is September 21, 2026, 10:41:09 AM
Author Topic: No Mach3 Found Running  (Read 26364 times)
Offline kolias
  •  1,165 1,165
Re: No Mach3 Found Running
« Reply #10 on: September 30, 2012, 05:40:31 PM »
Today I was determind to resolve my problem why LC could not post the gcode to Mach and I succeded.
My reasoning was since I have a Laptop in my office which has Mach/LC and work fine regading this problem there must be a reason. So after some thinking I discovered that the Laptop had an older Mack vesion (3.042.020) and later I just updated the existing Mach on it with the newer version (3.043.022).
So on the cnc computer in my shop I removed Mach & LC thru the contol panel PLUS I used the registry editor and deleted all entries related to them.
Then I re boot and installed Mach 3.042.020 including LC. After re boot VOILA ! LC now post the gcode to Mach with no problem. Then I installed Mach 3.043.022 on top of the older version including LC and again LC posted the gcode with no problem.
So my conclusion is that the newer Mach/LC version has something which does not allow posting gcode from LC to Mach
Nicolas
« Reply #11 on: January 05, 2013, 04:29:32 PM »
I too am having this problem having re-installed the latest lockdown Mach3 version on my new W7 computer. I have messed about with the problem without any success.
 Has a solution to the problem been found that does not involve an old version of Mach3?
tmsmith
« Reply #12 on: December 02, 2013, 10:17:51 AM »
Hello,
I have recently downloaded the latest mach 3 and lazy cam on two different computers and now have the same problem discussed in {No mach 3 found running dated September of 2012 under Lazy Cam discussions. Was there ever a resolution found for the problem ? My condition is just as described by Nicolas.
Thanks, Scott
Offline kolias
  •  1,165 1,165
« Reply #13 on: December 02, 2013, 05:13:01 PM »
Hey Scott, try what I did on reply 10 above. Perhaps it may solve your problem
Nicolas
« Reply #14 on: December 03, 2013, 03:08:15 AM »
Nicolas,
Thank you for your insight into this problem. I will give that a try. You would think they would have repaired the newer version by now. My older installs work as they should as well.
Scott
