Hello Guest it is October 04, 2026, 09:40:30 PM
Author Topic: exact stop vs cv mode  (Read 44661 times)
« on: October 11, 2012, 08:21:12 PM »
Well, I don't know what I would do without this forum
I appreciate any one who can help to keep me moving forward
My new problem is I lost my "all reference home"
I do have the yellow abnormal light on
I read everything I could find on the yellow flashing abnormal light
and I realize it is an alert to a irregular condition....
But, I do have yellow lights on m1 limit and m1 home on the
diagnostics screen....
I can't get those to go out....
when I try to "all reference home" the z axis reverses off the home switch and
the "reference home" cycle stops right there with a message "triggered limit switch"
I suspect this problem is link to my yellow lights on M1 limit and m1 home
thanks in advance for taking the time to help
Re: exact stop vs cv mode
« Reply #1 on: October 12, 2012, 01:47:50 AM »
Sounds like you may have noise or dodgy switches. If the Z references fine (machine coords go zero for it) then it is likely your X that is the problem. You could try setting a ddebounce interval of 2000 in General Config to see if it makes a difference.
« Reply #2 on: October 12, 2012, 02:38:35 PM »
well, I found the configuration for de-bounce interval.... it was set on 100
I set it to 2000 but, it do anything different
after hitting reference home the z axis zero's out reverses off the switch and stops
with triggered limit switch....
It started doing this after I created a sample project on Cut 2D....By accident I checked
"scale data with job" when I ran the program x and y both went in the opposite directions
of the home switch when it became apparent they had no intention of stopping
I hit the E stop just about the time it crashed....I don't think it hit and if it did
it didn't hard....
before I proceed don't I need to see if I can't figure this out ??
« Reply #3 on: October 12, 2012, 02:50:16 PM »
Try to reverse signal from the switch config menu.
Try active low or high for the X and Y axis.
Just a guess.
Jeff
« Reply #4 on: October 12, 2012, 03:18:36 PM »
okay  this is what I got
on x- and x home... active off moves away from home swtich
x- and x home both off... moves away from home switch
x- off and x home on...moves opposite direction
both checked on nothing....
I never did get it to move toward the home switch
does this tell us anything??
« Reply #5 on: October 12, 2012, 03:20:02 PM »
Can you attach your xml please and I will see if there is an issue in your config.
« Reply #6 on: October 12, 2012, 03:44:34 PM »
I know you have explained this a thousand times on this forum
but, could you explain where to find and how to
get an xml and I will send it
thanks!!!!!!!!!
« Reply #7 on: October 12, 2012, 03:47:21 PM »
Open Mach and look lower right at the profile name. Close Mach and browse to the main Mach3 folder and look for a file with the profiles name and a xml file extension. Copy it to your desktop and rename to something like trparker.xml then use the additional options button on the reply page to attach to the forum.
« Reply #8 on: October 12, 2012, 04:02:42 PM »
I sure appreciate you looking at this
this machine is like 2 weeks old
I hope I had messed the thing up
« Reply #9 on: October 12, 2012, 04:19:03 PM »
you know out of  curiosity I opened this file
and it is empty ....
the profile name is S720 and I did exactly
as you said...I will go and look for another
