Hello Guest it is September 10, 2026, 01:07:36 AM
Author Topic: just starting help Z axis DRO  (Read 10383 times)
Offline cgabe
  •  10 10
« on: October 19, 2012, 10:15:16 PM »
I am just going thru the tutorials and evrything seems to work but when I run the sample files the X & Y DRO read outs change as expected but the Z axis DRO stays at OOOOOOO and never changes even when there is a new z position in the command line.    The white outline showing the tool position changes as the file is run thru but  the DRO. stays at zero.  I am upgrading from an old DOS based system and these screens seem great!
any help?
Thank you
  •  9,368 9,368
Re: just starting help Z axis DRO
« Reply #1 on: October 20, 2012, 12:42:47 AM »
Could you post a small example of your GCode ?? (Additional Options : Choose File)
« Reply #2 on: October 20, 2012, 09:37:14 AM »
Do you have the Z motor enabled?
Offline cgabe
  •  10 10
« Reply #3 on: October 20, 2012, 09:54:05 PM »
Thank you both, I went thru the configuation instructions again and it now works
Thank you!!!
