Hello Guest it is December 26, 2024, 06:15:07 AM
Author Topic: Plasma Consumable Tracking  (Read 48982 times)
Re: Plasma Consumable Tracking
« Reply #20 on: October 29, 2012, 10:45:48 AM »
OH NO the secret is OUT(;-) My wife is REALLY the master mind behind all this. She is just bashfull.
« Reply #21 on: October 29, 2012, 10:54:38 AM »
So would that be she was smart or / ______ enough to marry you. (fill in the blank)
Keep up the fine work.
You could make the screen set available, cause I'm having way too much fun engraving to program.
« Reply #22 on: October 29, 2012, 11:05:28 AM »
DUMB is the correct word (;-) I guess we could modify the stock PLASMA screenset. BUT who uses those?
« Reply #23 on: October 29, 2012, 11:12:13 AM »
I modify everything for my use, but I am sure I'd use what you came up with as a great starting point.
Then I'd say you are the Smart one for letting Sherry straighten you out.
« Reply #24 on: October 29, 2012, 07:43:22 PM »
SO are ya ready for the next episode of "How the Plasma World Turns" starring the AutoScale Function?
« Reply #25 on: October 29, 2012, 09:06:17 PM »
Terry, about modifying the m30 and the m1030 macro. where are they located? be damned if i can find them unless its too obvious am i am just dumb.
« Reply #26 on: October 29, 2012, 09:21:35 PM »
You do not modify the M30 Just the M1030. You MAY NOT have an M1030 so you have to create it.
WHen the M30 runs it CALLS the m1030.
« Reply #27 on: October 29, 2012, 10:56:13 PM »
 ;D Ok Terry. I inserted a couple DRO's on the Program page in the lower right corner, modified the M1030. And believe it not, it works!!! Sweet little addition. I made a quote and invoice database in Access and with this little trick I can easily plug in my total inches and pierces into my cost figures. Sweet, sweet, sweet!!! I was having to keep so many notes and have to pull up the drawing files all the time to compute this stuff.
Thank you, Thank you my friend,
GL
« Last Edit: October 29, 2012, 10:58:16 PM by scbrniddvl »
« Reply #28 on: October 29, 2012, 11:01:29 PM »
Now I guess I'm ready to start on a consumables page. That will be a great help in figuring cost numbers. Tell Sherry Thanks to.
GL
« Reply #29 on: October 29, 2012, 11:06:06 PM »
GL you do know that the function can WRITE and update a file on the fly. WHy are you still transfering it by hand ??
(;-) LOL , (;-) TP
