Hello
Guest
it is
October 06, 2024, 08:18:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
MAch XML file location? Problem downloading MACH3 manual?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MAch XML file location? Problem downloading MACH3 manual? (Read 3748 times)
bobmorey
6
on:
October 30, 2012, 03:59:28 PM »
Can someone point me to the location of the xML profile for my machine. It loads in the Mach loader but I do not know where the actual XML file is located.
Also I cannot seem to download the user guide or Mach3 manual. My IE gives the message "file is damaged and cannot be repaired". I tried restarting the pc and downloading it a second time and get the same message.
Bob
Logged
Carnoustie, Scotland
Re: MAch XML file location? Problem downloading MACH3 manual?
Reply #1 on:
October 30, 2012, 05:43:13 PM »
Your xml will be in your Mach3 folder.
Are you trying to open the manual in IE or are you selecting to save it?
Logged
bobmorey
6
Reply #2 on:
October 30, 2012, 08:21:54 PM »
Hi hood,
Thanks for the reply. That is the folder I thought it should be in as well but could not find it there. Found a folder named XML backups.
Sorry, yes I was trying to save the manual. It opened ok, at least the first time.
Bob
Logged
Reply #3 on:
October 31, 2012, 03:49:00 AM »
It will definitely be there, the backup folder contains backups of your zml that Mach automatically makes periodically.
It sounds like a browser problem, you should be able to save it fine.
Logged
Print
Pages:
1
Go Up
« previous
next »
