Hello
Guest
it is
September 01, 2024, 03:36:05 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Running through limits on Smooth stepper
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Running through limits on Smooth stepper (Read 2859 times)
StefanV
11
on:
November 04, 2012, 08:32:24 PM »
I installed a smooth stepper on my 3-axis mill. Homing goes great including the slave axis where each stepper touches the inductive limit switch and backs off independent.
For regular operation the machine completely ignores the switches as limits. I can jog straight through them. I know I should be setting my soft limits but I really want to find out why the machine doesn't stop when it hits the limits.
Any settings I overlooked?
Any ideas?
Stefan
Logged
Carnoustie, Scotland
Re: Running through limits on Smooth stepper
Reply #1 on:
November 05, 2012, 03:13:07 AM »
Attach your xml and I will look and see if there is a problem in your config.
Logged
StefanV
11
Reply #2 on:
November 05, 2012, 06:42:29 AM »
Here it is.
Stefan
Logged
Reply #3 on:
November 05, 2012, 06:53:06 AM »
You dont have limits set up, you only have homes set up.
If you wish to use the same switches for Limits then all you need to do is enable the respective axis limits an set to the same port and pin number as the home on that axis.
Logged
StefanV
11
Reply #4 on:
November 05, 2012, 06:55:47 AM »
Always learning, thanks for the advice!
Stefan
Logged
Print
Pages:
1
Go Up
« previous
next »
