I noticed the white screen thing recently. It happened on a fresh install of mach on my NEW laptop that I use to write and debug code.
I thought I had installed the same version as I have installed on my CNC machine.
I copied the XML file from my CNC to the laptop to quickly transfer all the same settings. Upon starting Mach on the laptop I got a white screen instead of the control panel. I re-installed the correct version and it was fine. I later had a look at the two XML's and they were different. One had some extra commands at the top. I would have thought the XML would have some notation at the top to say what version it came from. You know - the usual documentation. All I could tell was they were quite different in the first few lines.
Also adding to the confusion is that in the mach directory I found three xml's by slightly different names for mill. I couldn't remember which one was the name the program was using. So I put an X in front of the names one at a time and restated Mach. I guess when I got to the one it was looking for (and it wasn't there) I think I got a white screen as well.
So, in the case of the previous posts, maybe the XML was being corrupted by the flakey computer?
Hood:
You ask a lot of people to send you their XML's for analysis. Out of curiosity, how do you tell if it's correct for the version they're running?
Or if it's complete. There's a ton of stuff in there.
Sage
