Hello Guest it is February 27, 2025, 08:56:55 PM
Author Topic: output 3 oem codes?  (Read 8878 times)
Offline comet
  •  338 338
output 3 oem codes?
« on: February 06, 2013, 07:42:07 AM »
hi cant find the codes to switch output 3 on and off any ideas?
  Tony
Re: output 3 oem codes?
« Reply #1 on: February 06, 2013, 10:05:08 AM »
ActivateSignal(output3)
DeactivateSignal(output3)
Offline comet
  •  338 338
« Reply #2 on: February 06, 2013, 11:11:39 AM »
does that go for on the screen buttons as well?
« Reply #3 on: February 06, 2013, 03:59:24 PM »
Yes if you use a VB button.
Offline comet
  •  338 338
« Reply #4 on: February 06, 2013, 04:49:31 PM »
well i guess the simple thing is to move it to the next free output number 5
« Reply #5 on: February 06, 2013, 04:55:03 PM »
Why? Just as easy to put a VB button on screen, you can even make it toggle it on/off if you wanted.
Offline comet
  •  338 338
« Reply #6 on: February 06, 2013, 05:14:46 PM »
ah yes but i dont know how to put a vb led on in screen 4
« Reply #7 on: February 06, 2013, 05:16:25 PM »
Thought it was a button to switch Output 3 on and off you wanted?
Offline comet
  •  338 338
« Reply #8 on: February 06, 2013, 05:22:16 PM »
sorry yes but i also need an led to flash when output 3 is on (drawbar) output 4 swings the carosell in
« Reply #9 on: February 06, 2013, 05:27:23 PM »
Well if you wanted to put a VB button on screen its easy, just add a button in screen4 or Machscreen and choose for it to be a VB button instead of choosing the OEM code or function option.
Then when back in Mach3 you go to Operator menu and choose Edit Button Scripts and it will flash, click it and enter the following
If GetOemLED(854) Then
DeActivateSignal(OutPut3)
Else
ActivateSignal(Output3)
End If
 Then save and exit the editor and you have just made a toggle button that will switch Output 3 on or off depending on whether its already on or off.
The LED will be  Output 3 LED and you can add that to the screen page beside your button if you wish, just add a LED in Screen4 and set it as OEM 854
