Hello Guest it is May 23, 2025, 02:19:31 AM
Author Topic: Soft limits broke in Turn?  (Read 16137 times)
« on: February 09, 2013, 04:43:49 PM »
I have Homing working well on my ORAC now and was attempting (unsuccessfully) to set up soft limits today.
Searches show a range of posts from "soft limits don't work at all in Turn" to "X works but not Z" to "Z works but not X" to "it's on the list to be fixed" to "it works great."
I seem to have trouble setting up anything new so it may just be me but am I wasting my time trying to make it worK?
Milton from Tennessee ya'll.
Re: Soft limits broke in Turn?
« Reply #1 on: February 09, 2013, 05:06:33 PM »
i've set softlimits on machturn, and on an orac.
« Reply #2 on: February 09, 2013, 05:15:14 PM »
They were fixed a while back, have them set on the big lathe and they are fine but its an older version of Mach  (057 i think) I use so may be broken in the latest. Wouldnt recommend 066 for a lathe anyway as there is at least one issue regards wear offsets in that and the Dev version and I also had some other weird things happen. Seems fine on Mill but Turn I would avoid the lockdown and Dev versions. Brian was told but not likely to get sorted as nothing ever does get sorted in Turn.
« Reply #3 on: February 09, 2013, 05:26:15 PM »
Thanks, I'm using .022 for the moment because I've been shy about updating and unknown things suddenly going tits up.  I guess it's time I should try a later version and see what happens.  Is it difficult to revert back to an older version if things go bonkers?
« Reply #4 on: February 09, 2013, 05:26:56 PM »
i use Version R3.043.022
« Reply #5 on: February 09, 2013, 05:29:33 PM »
That may be too old, think you will have to go about 056 or 057 or there abouts.
« Reply #6 on: February 09, 2013, 05:39:06 PM »
Yep, I'm a Luddite idjit.  I just read the changelog and softlimits weren't fixed 'til last year sometime.  .022 is 2009 I think.  I'm off now to try a less ancient version.  If ya'll see a huge explosion in west Tenneessee on the 10:00 news, raise a glass in my memory willya? ;D
« Reply #7 on: February 09, 2013, 06:33:59 PM »
what's improved from Version R3.043.022 to the current 066.
« Reply #8 on: February 09, 2013, 06:36:13 PM »
For me the biggie was the tool DRO  the Tool description and a few other little things.
« Reply #9 on: February 09, 2013, 06:38:32 PM »
just going through the changelog.
