Hello
Guest
it is
August 31, 2024, 08:44:01 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
relay control headache
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: relay control headache (Read 3711 times)
ryckmans_t
51
on:
February 23, 2013, 08:32:33 AM »
Hello folks,
I am new to Mach 3 again (- I dabbled with it last year). My breakout board is similar to this one:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=181075135780
I follow this advice:
http://www.buildlog.net/blog/2010/07/mach3-laser-cutter-setup/
I am trying to setup mach3 so I can switch the relay on/off using M3-M4 and M5 or E1Px.. and can't get it to work. I read everything I could around, but still don't get it. The mill works, with this pinout
X 2-14 (step pin =2 dir pin = 14)
Y 16-3
Z 7-8
A 6-5
B 4-17
whatever I do in the MDI (M3, M4 M5 with a small move after, or E1P1 E1P0)... nothing happens. The relay does not click (I also check with a continuity meter - no connection is made)
could anyone talk me through the setup? I know it's basic... but I can't get it to work!
many thanks
Thomas
Logged
Jeff_Birt
1,107
Re: relay control headache
Reply #1 on:
February 23, 2013, 08:41:51 AM »
Those settings are all of your axis settings, they have nothings to do with controlling outputs (relays). You need to go the Outputs tab in Ports and Pins and tall Mach what Port/Pin your outputs are on. Then go the the spindle tab and make sure that things are set up correctly there.
Logged
Happy machining , Jeff Birt
Check out
www.soigeneris.com
ryckmans_t
51
Reply #2 on:
February 23, 2013, 08:57:05 AM »
Thanks Jeff - I just wanted to show which pins I have available.
In Motor Output, I have Spindle disabled.
In Output Signals I have Output#1 activated, I set it to Port 1 and pin 9. How do I know which output my relay is connected to? Unfortunately I don't have the setup sheet for my breakout board anymore...
What setting do I need in the Spindle Setup?
At the moment in Relay Control I have
"Disable Spindle relays" is NOT checked
Clockwise (M3) linked to Output 1
In Motor Control
"Use Spindle Motor Output" is NOT checked
.. many thanks
Thomas
Logged
ryckmans_t
51
Reply #3 on:
February 23, 2013, 09:06:15 AM »
Also, if everything was setup'd fine, would I be able to switch the realy on/off by using M3-M4-M5 or E1P1/E1P0 in the MDI?
If I type "X0.1" in the MDI the machine moves, but if I type any commands from M3-M4-M5 or E1P1/E1P0 I get a beep only...
Logged
ryckmans_t
51
Reply #4 on:
February 26, 2013, 05:38:42 AM »
Finally found the problem...
I was looking at the relay contact with an ohmmeter - never got a signal. Then I had a look at the diode sitting across the relay contacts with a voltmeter - M3/M5 did indeed change the volatge across that!
It turns out that this breakout board is powered by a USB cable and did not get enough current to switch the relay on/off! With a better 5V power supply, things are working now...
cheers
Thomas
Logged
Chaoticone
5,624
Precision Chaos
Reply #5 on:
February 26, 2013, 09:47:17 AM »
Logged
If you could see the things I have in my head, you would be laughing too.
Print
Pages:
1
Go Up
« previous
next »
