Hi John,
This may only be my ignorance as I have never worked with a Laser cutting application before. The SMT Stencil needs to be accurate with a very good/sharp edge. Since the unit I am attempting to utilize is only 1W (and I consider this very low power for a cutting application) I wanted to utilize "full power" in the cut.
In order to dial-in the fine edge I require, I felt that I would need to pulse the laser so the material does not burn. I've run this buy the vendor that sourced the laser diode and optics and he concurred.
I need to go through (at least) 0.005" material, and I don't believe anything but full power will accomplish this...
I noticed that my table (and I assume any table) ramps up/down with speed... furthermore, I want to be able to set speed in my G Code... I'd like to build a "follower" circuit that will vary the laser pulses, such that the pulses are uniform across speed changes... this would require some varying signal to come from MACH3 (easiest) or the Mill itself to trigger the Laser.
As I admitted, I have no Laser experience, but theoretically, if I need a desired cut *depth* without burning, I'd need to pulse the 1W Laser rather than varying the output.... but, I'm open to new, more experienced thinking.
Thoughts?
-charlie
