Hello Guest it is December 26, 2024, 10:45:09 AM
Author Topic: Opto Disc  (Read 3894 times)
Opto Disc
« on: March 15, 2013, 05:45:23 AM »
Hi, i am in the process of machining a slotted disc for the spindle for pwm signals for  my cnc lathe retrofit but am unclear if the latest versions of Mach 3 support multiple slots plus a wider index  slot. I have read that  you can now only use  one slot so can somebody who really knows please clarify this as i would prefer to use multiple slots for greater accuracy if possible.
Many thanks
Charlie
Re: Opto Disc
« Reply #1 on: March 15, 2013, 06:12:39 AM »
Single slot and multi slot was found not to be of advantage.
Re: Opto Disc
« Reply #2 on: March 15, 2013, 06:16:43 AM »
Thanks Rich, single slot it is then.
Charlie
Re: Opto Disc
« Reply #3 on: March 15, 2013, 06:31:35 AM »
I use a Halls affect sensor instead of a slotted disc. Easier than trying to mount a slotted disc.
FWIW,
Re: Opto Disc
« Reply #4 on: March 15, 2013, 07:01:22 AM »
Also would suggest not to use the lockdown or Dev versions as they have issues, especially with Turn. I would suggest you go to the ftp site and download an earlier version. I use 057 but others seem to like 062.
ftp://anonymous@machsupport.com/Mach/
Re: Opto Disc
« Reply #5 on: March 15, 2013, 10:56:27 AM »
Thank you Hood, will bear that in mind.
Charlie
