Hello Guest it is December 21, 2024, 09:14:55 AM
Author Topic: Who can i call to get help with a setup problem on Mach 3  (Read 3805 times)
« on: March 29, 2013, 02:03:33 PM »
  I have a mill setup with Mach and been having a hard time getting it going.
I think we are close but i would like to call someone to go threw a quick trouble shooting.
R/C guy / Working in shop with a new products designer / I have a ACER 3VK Mill With MACH3 and a DRO II 3M on it.
Re: Who can i call to get help with a setup problem on Mach 3
« Reply #1 on: March 29, 2013, 02:09:58 PM »
Sent you a PM
« Reply #2 on: March 29, 2013, 08:37:24 PM »
  Thanks Brett ;D ;D ;D
You got us a lot further along. ;)
We found the wiring wrong on the Z axis servo motor. ???
It was a great feeling to see  it move. 8)
  Is there a setting in Mach to tell Mach that it is looking at C32 board.
Problem we are having is setting up the steps per inch but when we
give it a move command it goes a totally different distance.
« Reply #3 on: March 29, 2013, 08:49:04 PM »
There is a complete chapter dedicated to this in the manual.
Mach3 Install & Config. Guide
Up top, under SUPPORT/Documentation
Russ :)
« Reply #4 on: March 29, 2013, 10:45:46 PM »
Good, you will be slinging chips in no time now.   :)
A couple of these links will help in setting up your steps per and a couple of others that you will want to check right after you get everything moving the proper distance.  Also, the manual Russ is referring too really is a must read for Mach users.  You will be doing yourself a favor to study it front to back.
http://www.machsupport.com/forum/index.php/topic,16315.0.html#new
http://www.machsupport.com/forum/index.php/topic,12512.0.html#new
http://www.machsupport.com/forum/index.php/topic,10308.0.html#new
http://www.machsupport.com/forum/index.php/topic,12513.0.html#new
« Reply #5 on: March 30, 2013, 12:06:41 AM »
  Got it.
This is great.
We are finally getting somewhere.
