Hello Guest it is December 26, 2024, 03:23:48 PM
Author Topic: Text wizard/engraving issues  (Read 10848 times)
Re: Text wizard/engraving issues
« Reply #10 on: April 14, 2013, 11:39:39 PM »
Hey all. Just to update, I had backlash issues on both the X and Y -- the X ballnut had come loose from the saddle, and the two jam nuts on the Y axis leadscrew had also come loose allowing the screw to move. I was finally able to identify the issue(s) when I slowed the motors down to see if it was a motor tuning issue.
After tightening both up properly, the engraving has cleaned up quite a bit. I still have a bit of an issue, but it's *FAR* better than it was. I'm going to have another go at the machine to figure out where I still have some slop later this week or this coming weekend.
Thank you all for the nudges/pointers in the right direction; it's been a HUGE help.
