Hi Guys,
i bought a new CNC-Mill machine with SMC-TR-1000 Controller.
It have 2 connect options: USB and DB25.
Under USB i work with Frontplattencreator.
I would like to use Mach3, so i bought Ethernet-Smoothstepper and configured with Manual and connected to DB25-Connector.
I entered the DB25-Interface Pins in Mach3 about X/Y and Z Steppers and saved it.
Mach3 recognizes the Smoothstepper and the LED´s shine but when i started a test NC-Program nothing moves.
Does anyone know why it not works?
The Seller says that the Controller works with Mach3 under DB25 so the problem is by the Ethernet-Smoothstepper...
Thanks for Help
DomeBB
