Hi everyone,
I`m a newbie using mach3.
I´ve been searching auto tool and auto zero makros and setup but what i`ve found so far is the pieces of info which are quite confusing for beginner. I know there is a lots of info about this topic, but its difficult to put all the pieces together.
The issue:
I am using V-carve pro for code. So far i have saved all the different tools in different codes. So running, for excample 5 different tool job, i have to save 5 different codes and load these one by one to mach3. And change the tools after loading a new code. Now, what i wanna do is save all the different tool path in the same code, load it to mach. Ok, for code i choose now ATC postprocessor in v-carve pro and this is ok. Enable tool change in mach. I`ve tried it and it works so far- after each tool code, it stops and waits for tool change.
Now i want is that after every tool path, mach will go to certain tool change position (where ever it is), Z goes up, i change the tool, goes to fixed Z auto zero probe and continous cutting.
Probably simple question for most of you.
Is there an simple step by step tutorial to set this up? setting macro and setting fixture for auto zero
appriciate your input.
Taniel
